Cleaning Cylinder
rocks rev
Must have stuck a ring or something (got it hot??) and have alunimum stuck to the cylinder. How do I clean up the cylinder?:confused:
Be careful but you can clean em up with miratic acid. It eats aluminum. Take your time and you can get them to clean right up.
Jake
X2.................if I could add, a Q-tip dabbed in the acid and applied to the area works very well. Yes, take your time and it works great. Rinse with hot soapy water when finished.
Thanks guys:beer; What would happen if sled got real hot, also what would happen if actual water went in intake on side panel? It's my brothers sled and happened last spring so I don't know exactly what happened but the top edge of the piston on the mag side towards the intake is missing some aluminum, but the PTO side is fine.
