Guys Please only post pictures and information that is about or helpful in decending or climbing chutes.
BF is this the one.
when going down something this steep , you should put a old belt around your ski ,to keep from going to fast ,I have also put my sled in reverse and blip the throttle going down , works , but never tried it on something this long
Which part the reverse or the belt. I have done both and the belt works better then you would think. The reverse trick is ok until you burn up your belt then you only use that trick in emergencies.does that work? sounds logical i guess. what i am wondering is if it would make the sled pull to one side?
i was refering to the belt. if it was that bad where i thought i would have to use reverse, i would probably just turn around. but, thats just me.
You know it takes bad choices to make experience. Cant have one with out the other.I dont turn around to often , like to explore new areas , unless it is to dangerous , then ya I find a different way , but I have been known to make some bad choices............but its all good .......
