I would guess this would work just fine. Have a welding shop do it. I was going to do this on a set of rev arms. May have to do some stragic bending on the lower arms as if you cut them in a couple inches they taper in so you will have to figure out a way to lightly bend them out to be the right width. The best wat to take care of it all would be to have a summit to measure. Make sure that the arms do not have a different angle coming off the bulkhead. Also buy a metric tap for the radius rod. Cut the end of the radius rod down that has the standard rh threads. If you cut the other end down your gonna pay an arm and a leg for the left hand tap.
