Checking a used crank?
ridgeclimber
I just purchase a used crank and I am waiting for it to arrive. I was reading my manual on checking the run out, rod bearing side play and checking the bearings. I plan on checking all of that to double check it. My question is are the inner main crank bearing sealed? I do not see any inner seals listed in the manual. Also should I replace the bearings or just run it if they look good? Thanks in advance for your input.
