Just a quick reminder now that the season is starting up. If you don't have air in your canister, an airbag is no good to you.
Especially those with Air-filled canisters (BCA and SnowPulse)! Make sure you check your canister to see that you have air pressure in your canister. We have found several air-filled canisters that have leaked down a little during the off-season. If your air-filled canister is less than 2200 PSI, you need to have it topped off.
BCA canister needs to be filled to 2700 PSI at room temperature and SnowPulse needs to be filled to 3000 PSI.
For ABS, the weight of the canister (in grams) is written or stamped on the canister. Put your canister (without the canister cap) on a gram scale and verify that you are within 5-10 grams of the weight stamped on the canister.
