2015 viper tunnel,buckled,bent.
New sled less than 200 miles.
Sent from my ADR6400L using Tapatalk 2
head over to the polaris section, we have hundreds of tunnel fixing and strengthening plates!
never seen a cat like that, hope your dealer does something about it.
Yep, did that exact thing to a 2011 pro within the first hundred miles. It was from bottoming the rear skid and their rivets weren't getting a good grip.
Hopefully they warranty that, try stiffening your rear shock afterwards.
That right there is a prime example of Cat vs Yamaha build quality. If that was a Yamaha design it would come with a 20lb steel plate already in there, it'd weigh a ton but it wouldn't fold like tin foil.
M5
I have exactly the same problem on my viper with 400 miles. What did you do to repair yours and prevent reoccurrence. Looks like the arctic cat proclimb rear bumper from cat accessories adds some support to this area.
Had the same issue with my '12 HCR. Ended up dropping the suspension out with a middle shock relocate and using the lower holes on the rear mount.
Don't know where all that sit's with the Viper today but the easiest fix is taller bump stops for the rear arm on the rails.
Did you put anything in there to reinforce it?
