check engine light
Can someone get me the codes for the number of flashes for the check engine light on a 07 700 Dragon. I have an intermident bog at low throttle movement. Idles fine but quite often know it bogs badly. It will bog until I left off the throttle. I am thinking TPS. When it bogs it goes to limp mode and the check engine light is blinking once very slowly during that time. Then you can hear the idle pick up, the light goes out and it is good again. There is no deto going on, I have 35% 110 race fuel. I have removed the throttle safety switch out of the circuit. thanks
