My understanding is that when the exhaust sensor reaches a certain temp then the ECU leans down the fuel mixture-5%. So if it's not working you would be too rich. The 5 flashes indicate that the voltage reading is either high or low. The voltage range is .06 to 4.9 Vdc and R's above 3000. The ECU and electronics are basically the same so I'll bet the 2010 sensor works just fine. Maybe it gets a better reading deeper into pipe center.
As we all know, the DET system also flashes the check engine light indicating detonation. Not the 5 flashes you have though-solid while it's adjusting fuel and timing and then flashes the check engine light and reduces max R's to 6000 as step two.
Can anybody list what number of flashes mean what? Or where to get that info?... I think it would be handy to have!!
My 10Assault has been having the same issues. I will be goin along just fine and then all of the sudden it will spit and sputter and wont let me go over 6000rpms. Sometimes it will run fine but the check engine light will flash. I have talked numerous times with my dealer and they are as frustrated as me. They have hooked it up to their computer and all it says it that the DET sensor is the problem. Their 2 main reasons for tripping the sensor are bad gas or overheating. I have cycled through 2 different 92 octane tanks and boost, and i installed ice scratchers... FRUSTRATED!!!!!!!!!!!!!!!!
