charging the fuel pump
beamslayer
I am trying to remember which wires to run the fuel pump ? finely getting it back together I guess I should have started in the spring. Is it the DC wires hooked up to a 12 volt battery ?
You don't really have to charge it, just makes starting easier. You can just pull it over a few times, that's all I've ever done.
A completely "DRY" fuel system will still only require about 5-6 pulls to fully charge to the point that the sled will be running as long as you have sufficient fuel in the tank. Priming just isn't necessary.
Thanks guys I remember doing it on my 700 dragon so I just assumed and we now what happens when you assume .
