Changing to rack carbs on 01 sks 700???
Found a set of mikunis off a 2001 700. They are stock needles and mains. Would this be a good thing to have? Also what else will be needed in order to do this to swap? Thank you.
if you were running keihin carbs you will need a differant throtle cable and choke cable. and the oiler lines on the carbs need to be blocked off unless you are getting the intake boots with the mikunies . the oil lines connect directly to the mikunies and the keihin carbs the oil lines connect to the intake boots .
