How do you get the grips off of the stock bars without wrecking them. Its probably easy but I've never done it before. Changing from the pro tapers to the rsi. Thanks for any help.
I would just order new warmers and grips, along with a throttle block to make life way easier. This will also leave you with a bolt back on spare set of bars.
I use an air compressor. Just work your air nozzle under the grip a little ways, then have at it. It should just slide right off. Has always work for me anyways.
Air compressor works well, or you can work a screw driver under the grips, then spray some WD40 under the grip, twist and pull and it will come right off.
