Changing Crank Seals??
T
TheBreeze
M8 motor. What does this involve? Can it be done with the motor still in the sled? What is needed for tools? Thanks in advance.
Unfortunately no you have to pull the motor and disassemble it to install the seals.
A clutch puller is a must,piston puller and a good flywheel puller too and a way to support the motor a good sturdy rafter and a com along works. the rest of it standard and metric hand tools.:beer;
the M8 motor is actually pretty easy to manhandle, you can get it out by yourself pretty easy. I've pulled 1000's by hand no problem, the 8 is cake.
Clutch man, what do you mean by a piston puller? Never heard the term.
piece of cake.stripping and busting bolts off.bloody knuckles.never having enough of the right tools.praying it starts when all done.fun stuff.:)
Piston pin puller forgot the pin there sorry about that SLP makes a great one part #251-181
mcgyver would use a c-clamp and a block of wood for pin puller..you going to need allen sockets
You know snowmobiler i made piston pin puller out of a good heavy duty PVC pipe, washers and some all thread worked good if the pin was not stuck to bad. the good old days.:beer;
