changing 11 or 12 pro to belt instead of chain drive $$
Polaris had almost put out a belt drive kit to upgrade the previous years...they had a part number and everything... but never put it out there.
1332998 1 EA ASM-BACKER BELT 191.26MM
1332999 1 EA ASM-JACKSHAFT 15 SPL W/BRG
1911731 1 EA ASM-COMPL BRAKE SYS P/T 1/2
1911732 1 EA DISC-BRAKE 7"
3211146 1 EA BELT-QUICK DRIVE 68P 36W
3222204 1 EA SPROCKET-21T BELT 36MM 15 SPL
3222205 1 EA SPROCKET-44T BELT 36MM 15 SPL
5138275 1 EA BRACE-LOWER RH MACH
7080936 1 EA CAPLUG-#BPF-7/8"-6 BLACK
7518906 2 EA SCR-M8X1.25X25 8.8TXTR ZOD P80
7518953 1 EA SCR-M8X1.25X30 8.8 TR/TX ZOD
7519004 2 EA SCR-M10X1.25X20 8.8 HH ZOD P30
7519049 2 EA SCR-TXTH M8X1.25X35 8.8ZOD P80
7519236 1 EA SCR-HXFL-M6X1.0X16 8.8 ZYL NYL
7519243 2 EA SCR-HXFL-M8X1.25X25 8.8 ZODP30
7519260 3 EA SCR-TXTH-M8X1.25X20 8.8 ZODP30
7519338 2 EA SCR-RHCAR-M6X1.0X22 8.8 ZPC
7547332 6 EA NUT-M8X1.25,FLG,NYLOC-OLIVE D
7547505 4 EA NUT-HEX-M6X1.0 8 ZOD NYL
7556588 4 EA WASHER-6.2X14.25X2 ZC
7621467 7 EA RVT-3/16(.251-.375)ST-ST-LF-B
7661637 10 EA RIVET-3/16-.090-.290
9924077 1 EA INSTR-QUICK DRIVE KIT
9924158 1 EA INSTR-BELT INSTALL/HANDLING
9800081 1 EA BOX-18"X12"X10 -D.W. CUSTOM
9800483 2 EA BAG-BUBBLE WRAP,8X15 1/2
9810321 0.015 EA PACKING TAPE #250-3"
9820042 1 EA LABEL-4X2
9820044 1 EA POLY BAG-RECLOSEABLE 12X15.004
9820048 7 EA BUBBLE MASK-BMC-120,18"X6"PERF
If you want to go with a belt drive... I'd recommend going with a TKI or C3 drive kit and run a QuickDrive Bearing plate. Your stock driveshaft will work in a pinch from what I understand.
Somewhat off topic:
Interesting that in the upgrade kit they were going to supply a plug for the Chain Case Drain hole in the Fender, but never bothered to install that plug in any of the QD production sleds. 7080936 1 EA CAPLUG-#BPF-7/8"-6 BLACK
If your serious; I would start a WTB thread, there are bound to be new take offs available for far cheaper than paying new prices. I know I have an extra bearing plate and a box full of stock sprockets, I'd like to find a new home for. FWIW
I ran those parts into an online order website, way cheaper to buy an aftermarket kit.
That is my guess why they didn't go ahead with the polaris kit.
You can pretty much buy everything you need off of ebay or here for around 350 to 400 dollars if you use your stock drive shaft
The plate is p/n 5632556
And then the 13-15 Pro belt drive kit from TKI will fit right on.,
Chris
Did this on my 11, works great, relatively easy, sled feels a lot snappier.
It's amazing how much the chain case, gears and chain weigh compared to the belt drive parts.
I bought the following parts off e-bay:
Backer plate
Jackshaft w/13 brake rotor
Sprockets and QD belt
Used original driveshaft and brake caliper.
Mostly bolt on with the exception of grinding off small piece on bulkhead to allow backer plate to mount flush and drilling out brake caliper mount holes slightly to allow larger 11 bolts to pass through.
Hope this helps.
One downside to stock setup is that is does not have a tensioner like the aftermarket. Thought I saw just a tensioner someone adapted to the stock setup though.
Sent from my SGH-I337M using Tapatalk
