Add a 3rd pulley to the QD system, something like what C3 or CMX uses.
I would say outside to put more teeth on the top sprocket but if the cast pulleys are out of true its still gonna go through a constant tighten loosen cycle. Also wouldn't a machined pulley cut down on break in time?
The best bet would be to have Gates make them a kevlar poly reinforced belt, they would not have these "break in" or wear issues.
They went cheap. Tried to make it all a proprietary desing, as in special pitch and width. Heaven forbid they make it so someone could buy a better belt... Typical!
Go find someone with a new CMX belt and look for a bunch of blue waxy stuff all over the like the black stuff you see on the Polaris belt drives.
True machined pulleys and a straight driveshaft,
If it doesn't have a tensioner pulley next year i will be shocked!
Is a tensioner really the answer? C3 calls for a 1/2'' of deflection in their set up and mine is way tighter than that already.
