IN THE MIDDLE OF GETTING THINGS BACK TOGETHER. REPLACED CHAINCASE, WHAT ARE THE TORQUE SPECS FOR THE CHAINCASE MOUNTING BOLTS? AND COVER BOLTS?
THANKS ALOT GUYS!
Chaincase bolts=28-30ft-lb
Cover bolts=10ft-lb[/QUO
is there a torque number for the grears themself?
or just tighten them up..im planning on goin from 41 to a 42 on the bottom.
Top gear Castle Nut is 50 ft. lbs. Make sure you put the cotter pin in.
Bottom gear nut is 19 ft. lbs. Put a dab of blue locktight on this one and make sure the bevel washer is facing out. Just note how it is when you take it off.
