Use ATF, i think pretty much everyone uses it and it works realy well, and is also cheapI did a search and found the following suggested:
Evans - can't find anything about it.
Does anyone use Royal purple max lube? if so what weight?
Polaris's lube seems to allow too much wear (to much metal in the lube).
Thanks
I find myself needing to add lube every ride, so does my brother. Maybe we both have bad seals cuz sometimes it leaves puddles on the groundI use the Polaris synth chaincase oil. The chaincase uses so little, there isn't much money to save by going with ATF. It's not a consumable like 2 stroke oil is![]()
I've used Royal Purple, 75w/90 I think it was, and some other synthetics.
Are the recomended chaincase lubricants lower weight like straight 30W? I was wondering what they were.... I have to figure a heavy weight gear lube, especialy in below freezing temps, would rob a bit of power vs a light winter weight engine oil.... Like trying to sling around mud vs water...
ATF, very interesting... a lot of detergents, I bet the inside of the chaincase is spotless.... not too light... weird.... Yes I could see there being no difference in the cheap stuff vs the expensive Synthetics.... no need for the friction modifiers like a transmission does..... clutches and all....
The most important thing if you ask me is to change the oil often, not how expensive oil you put in. I use to change about every 500km, by then the oil starts to be a bit dirty.
