Chain tensioner set up
I just replaced my jack shaft on my 2014 m8000. Putting back to get her and on the tensioner time of the game and I m uncertain of how to put in in. Do I set it with proper tension and then it will take over from there or do you put it in loosely ( which does not seem right ) and let it tighten up some how on its own. I have it right now with about 3/8 of a inch of play on the non tensioner side is that to tight to start with? Thanks for your help in advance
Get rid of that auto tensioner is the best think put a manual tensioner in!!! Here is pic of my manual tensioner conversion I did. All Cat parts here is the parts list.
1-Screw Adjuster 2602-735
2-Nut 0123-150
3-Spacer 2602-707
4-Seal 2623-057
5-Ratchet Plate 2602-465
6-Spring 2602-336
7-Tensioner Arm 1702-342
IMG-20141130-00480.jpg IMG-20141130-00481.jpg IMG-20141130-00477.jpg IMG-20141130-00476.jpg
That tensioner arm came with the roller on it? I did a manual tensioner from One stop performance works awesome!!!
As for the auto tensioner, if your going to leave it w some slack like that make sure your track is off the ground and spin the track and clamp the break a few times so it adjust before there is a lot of pressure on the track
Yes the roller came on the arm already. It is all the parts off the 2014 XF 7000 cat
