Chain Tension?? Whats "right"?
On the Nytro, I have no idea how to tell how much tension or how tight the chain is...
On my Doos I could leave the cover off and adjust tension, or, use the old go finger tight then back off to get pin through.
Obviously that won't work on the Nytro.
I have a 19t top, 40t bottom.
I turned the bolt in with a wrench till I "thought" it began to feel slightly snug?
Heres a pic, I have about 1" of exposed threads (including the head of the bolt).
Any one else have a good method for getting the proper tension? Or can they measure their thread length (including bolt head)?
The manual says finger tight than back it off a little. You should be able to turn it with your fingers and then use two open end wrenches to get the nut tight.
Nikolai is correct. Finger tight & back off 1/4 turn. Tighten lock nut
Exactly. I have found, however, that if I take a small screwdriver and pry the rubberized washer away from the cover (toward the loose nut) I can turn the bolt with my hands much easier and you feel the tension on the chain instead of the resistance of the rubber washer.
thats how I do it as well.
ok, mb thats what i need to do...the rubber deal. cuz it was way too hard on the fingers to turn.
Thanks all!
Chain tension
Another way is to move your secondary back and forth, there should be anywhere from 1/4 to 3/8 of an inch movement at the very outside of the sheave. That was how Yamaha used to tell everyone how to adjust if my foggy memory serves me correctly.:face-icon-small-dis
Got it.
Backed off the rubber washer and nut.
Used a glove to get a better grip, and it loosened up enough to turn by finger, no prob.
Snug minus 1/4 turn = 1 1/8" . . very close to where I was I guess. :)
My chain may be slightly stretched for the 1/8" difference on adjuster. /shrug
