Chain oil
Hopefully putting the old girl back together Thursday, what chain/gear oil should I use? Some special Cat brand or just any type of gear oil out there suitable? What weights should I look for?
I use a synthetic 5w-20 but I am sure ATF would work fine! Just make sure it is still fluid in cold weather. Which ATF to use? most slippery? Mike
Thanks I was wondering the same thing! I have 4 chain cases to fill, last year I bought some full syn. chain case oil $12 bucks a bottle and it looked like ATF! I like the idea of full syn. 5 w 20, I will try it out
Keep it thin as possible, I use 5w 20 but really anything that will stay liquid in cold temps will work, ATF is just fine!
Mike
I've always just went and bought the cat stuff..its a few bucks, but you only need to change the oil in the case once a year (or maybe twice a year if you ride a LOT). Not a lot of money in the long run and you know you have the right stuff.
