D
Danbot
Anyone done a chain case removal on a 900? I need to change out the jack shaft seal, and I have a few questions.
-Will slacking off the track tension all the way be enough to slide the drive shaft over to the pto side to get the chain case out?
-The four chain case bolts.... will they stay in place? or will I have to create access to them from behind?
So far, I have the jack shaft out.... was hoping to be able to pop a new jack shaft seal into the chain case without removal, but I can see now that the brake rotor will not come out until the chain case has been removed or at least loose and tilted a bit.
