hey have yall had any luck with twins? im lookin at some for my dragon. is higher compression a must?
Unfortunately it's not just the pipes alone that make the setup perform. When your running correct system and all componants of your sled (sensors, transmission, track) are also correct it is easily the highest performance with the least financial outlay for the 800 CFI Polaris.
Call Carl's and do the entire package as they specifiy. You will spend more money then buying used "deal" stuff but in the end result you will be way better off performance wise.
pipes
head
clutching
ecu
fuel octane
spark plugs/caps
sensor programming
all critical componants of twin pipe performance.
any porting high comp head etc?
