I have a shower that I am doing and I am down to just finishing the floor. It is a shower in new construction on a wood subfloor with a membrane and concrete over that. Problem is the drain is as low as I can adjust it and I need another 3/16" of height. I am using the 2" x 2" small tiles and if I lay another layer on top it is perfect.
Should I:
Lay one layer of tile and go over to get height?
Use a thin set and re-trowel floor raising it a 1/4" (is this to thin? possibly will crack?
Get some type of floor concrete leveler re-trowel and add 1/4" then use thin set?
Also as a side question what is best for shower FLOOR, Ultraflex 3 or Keraldstik
Should I:
