Anybody have a link or info on this?
What wires splice into where?
Does it have to be a certain year CCU?
M8- M1000?
Anybody find a way to make a tach work? I have a digatron with tach inputs...
Either an 07 or 08 800 or 1000 ccu will work. The two yellows off of the M7 stator (ac) get wired to the two yellows on the ccu. There are two +dc output circuits ( a ccu plug from a wiring harness is helpful) a red w/blue and a red w/ black. The negative off of the ccu is black. Where the stock M7 regulator is unplugged the red w/blue can be connected together. The red w/black can be connected to the yellow and the black can be connected to the brown.
Unfortunately there is no purple on an M7 ecu like there is on an 8 or 1000 for a tach signal and the yellow circuit wont work anymore now that it is DC. I tried a few isolation schemes to get an AC signal to the tach, but they didnt work. A friend uses a cheap small engine spark plug wire tach and he likes it.
I am helping one of my friends out installing a big block and turbo on his M7,I had been planning to do a Boost It box for fueling but need to get a tach signal in order to hook up the Boost It box.
Is the yellow wire a tach signal?
If you mean, you are installing a big bore on the M7 bottom end and not using a ccu then the yellow is used as a tach input for most snowmobile tachs (which accept multi pole input pulses - boost it might not???? - dont know)
If you mean you are installing an M1000 or M8 motor then the purple wire coming out of the ecu is a tach input. I would assume you could use it for a boost it box.
The M7 is looking like a completely different animal than the M8 or M1000.....
