What happened to the rectifier drawing mountain horse?![]()
Not sure... it seems to be back up and I didn't do anything.
maybe a glitch in the system??
PM me if you cant see it after refreshing (reloading) the page.
I've looked over this thread but I apologize if this question has already been answered. My dobeck box is wired into the fused dc acc supply where it should be but my oil pump is wired into the unfused dc power supply. Since they both pull from the same source could I just add a 2 amp inline fuse to the oil pump side of that connector and leave it wired the way it is?
NOTE:
NOVEMBER 14, 2014
The setup, above, may not provide correct voltage as pointed out by 429dhm.
Until more info can be found... I do NOT recommend that my setup, above, be used.
I stick to my comments in the first post.
429... you bring up a good point. (bottom most drawings/info)
Wondering about "Peak" VS "AVG" DC output voltage??
Finding something like a LM7912 Linear VR BUT with higher amp capacity OR a zener may be needed to bring it down in voltage... and be simple.
Or maybe a simple 10-20amp "buck converter"
Like this one
http://www.ebay.com/itm/301391726562
With an input range of 9-35vdc and output current capacity of 20amp
Small size, 3"x3"x1.25"
This in conjunction with the Full-wave rectifier and capacitor would give you a very stable, near-pure 12V DC supply.
PONDERING THIS:
Too tired to ponder/study tonight.
http://www.electronics-tutorials.ws/diode/diode_6.html
Here is what I put up on the other thread in the "PRO RIDE" section.
"buck converter"
Like this one
