Which brand avy pack was it
There is only one bag on the market that has two air chambers (bags) that deploys with compressed air. I'm talking about the main system, not whose name might be on the side that it was marketed under.
Compressed nitrogen on these. All other brands are comptessed air.
Yes, not the point I was getting at though. My BCA also is compressed Nitrogen. The point I was getting at is there is only one system that uses two bags that deploy on the sides that use any form of compressed gas.
No worries and i followed you and guessed you knew. I was just pointing out that ABS uses nitrogen, and not compressed air, for accuracy for others reading it.
Interesting that you are running nitrogen in your BCA rather than compressed air. So you are using the bca compressed air canister and then filling it with nitrogen up to the pressure recommended for the compressed air? Or using a different cartridge and/or different pressure? With ABS cannister, the nitrogen is filled by weight. Do you fill your BCA by weight or pressure?
I don't see any issues, as atmospheric air is 78% nitogen anyway. Just curious why since nitrogen would typically be more expensive or harder to source than compressed air. And curious if you were given a hard time by whoever is filling (I'm not sure how, or if, the bca cannisters are labeled).
I work in the aircraft industry and have easy access to high pressure nitrogen.
