Cat weights in Axys primary
From my understanding the new 2018+ cat primary setup the belt to sheave is not determined by the weight, it floats around a bit before contacting the rollers. So really the profile might be good but it doesnt have the proper "shelf" in the heel area to work in a polaris clutch?
The new cat weights will not work in the Polaris primary.
If your interested I can give you Cat part numbers and their gram weight. That work with the 1/4” pin and the P85
Ok. Would it help to weld on a small pearl on the heel and grind to matching height?
Sent fra min S60 via Tapatalk
Problem with a small pearl. It will eat into where the weights seat in the moveable. First generation RXL clutches had a set screw located there(moveable) to adjust weight tuck under. That may work.
