1109cc Hooper/Crankshop Cat Triple For Sale. Based on Crankshop "Made in USA-1500" outer castings w/ Hooper triple exhaust port interior castings. Cylinders, heads & case ported and set up by Mike Reed of Lansing, MI ( one of Mike Crooks machinists ) 250+ HP, 65mm stroke - 85mm bore. Just freshened up, cleaned, honed, new rings, wrist pins, bearings, gaskets, crank seals, o-rings and stainless fasteners. Cut balance shaft, trued & welded crankshaft, 4 degree timing key. Complete motor w/ '97 t-cat ignition, carbon fiber reeds, 44mm intakes, recoil & brand new exhaust manifolds. All it needs is carbs & pipes.
$3500.00
$3500.00
