With 72g weights in primary sled pulls much better now but engagement rpms are still a bit high. Running yellow/white spring 122/285 in primary and orange in secondary at 3-6k ft everything else stock. If i remember correct a lower spring rate at 2.5in will lower engagement and a similar rate at 1.3in should keep top rpms same. Should also add I want to try glide washers on one side of primary spring (which adds ~200 engagement rpms) as mine looks like it binds constantly. So with a net result of lowering engagement a couple hundred was going to try cat gold 75/275 with a glide washer? Also looked at SLP 120/300 black silver and cat yellow/green 114/267 but first rate on SLP seems to high and finish rate on cat yellow/green seems to low....
How much of a drop will i see going from 122/285 to 75/275?
Thanks!
Thanks!
