I'm parting out my 2009 Polaris Assault that had a 2003 Carbed 900 Cat twin. If there is something else you're looking for from the Assault chassis or the Cat I may have it and not listed here.
2003 Arctic Cat 900 (Carb twin) Electrical; CDI and Harness, VR, Ignition Coils, Exhaust Valve Condense. $100
2003 Arctic Cat 900 (carb twin) Mikuni carbs, they need good cleaning. $100 shipped.
2003 Arctic Cat 900 (carb twin) freshly rebuilt crank, its in line bored cases but a couple of the base mount threads are really chewed up and there's a heli-coil in one of the jug bolt holes. (Colorado\Local only) $450 with cases, $375 just the crank.
2003 Arctic Cat 900 reed valves and cages; $60.
2009 Polaris Assault/Dragon Chain case; great shape, cases seals, tension, chain and gears. 20/41 HYVO. $75. Bare $100 w/gears and chain.
2009 Polaris Assault/Dragon SLP Exhaust and Can. The neck of the exhaust pipe has some sllts cut out of it and bent open (was used in the Assault chassis into a 900 cat header. Can easily be bent back to seal around Pol 800 header. $100 each. $175 both. (Colorado\Local only).
2009 Polaris Assault front track torque arm and limiters. $100.
2009 Polaris Assault Slide Rails and slides. Nice and straight. I have most of the hardware too if you need it. $150 pair (Colorado\Local only)
2009 Polaris Assault/Dragon Rear Axle Shaft,Spacers and Wheels. $75
2009 Polaris Assault/Dragon Spindles $75 each or $120/pr.
2009 Polaris Assault/Dragon Drive Shaft. $120.
2009 Polaris Assault front track torque arm. $75.
2009 Polaris Assault A-arms. Both uppers and lower left. Straight and with bushings but some paint chipping. $50/$50/$85.
2011/12 Polaris RMK Rear Skid Walker Evans shock (white coil over in pic) $100. Rear scissor; $75.
All prices shipped to lower 48 unless local only. Can also meet in Denver or Summit Co. CO, and or the Denver Snow Show.
![2009 Polaris Assault Dragon Exhaust Pipe 2.jpg 2009 Polaris Assault Dragon Exhaust Pipe 2.jpg](https://www.snowest.com/forum/data/attachments/221/221512-fa62de172cd9d92ce39f79d3ba4dbb70.jpg?hash=-mLeFyzZ2S)
![FS Part Out AC Electrical.jpg FS Part Out AC Electrical.jpg](https://www.snowest.com/forum/data/attachments/220/220914-cf487c79f4f95ed2a6a819f2e0e7a93d.jpg?hash=z0h8efT5Xt)
![FS Part Out Chain Case 1.jpg FS Part Out Chain Case 1.jpg](https://www.snowest.com/forum/data/attachments/220/220920-d4058944d8f986912aa10a47baa28f0e.jpg?hash=1AWJRNj5hp)
![FS Part Out HVYO.jpg FS Part Out HVYO.jpg](https://www.snowest.com/forum/data/attachments/220/220928-171b5803ab34c3cbeb2ca1a431f9f391.jpg?hash=FxtYA6s0w8)
![Assault Spindles.jpg Assault Spindles.jpg](https://www.snowest.com/forum/data/attachments/220/220939-11286cd63cf11d2d8e895984376c52bb.jpg?hash=EShs1jzxHS)
![FS Part Out Rear Shock.jpg FS Part Out Rear Shock.jpg](https://www.snowest.com/forum/data/attachments/220/220944-66b645dae77d58434c3abe496caa2f05.jpg?hash=ZrZF2ud9WE)
![2009 Polaris Assault Front Torque Arm .jpg 2009 Polaris Assault Front Torque Arm .jpg](https://www.snowest.com/forum/data/attachments/221/221489-bc6d0cc76419f92005debc41bc9c233d.jpg?hash=vG0Mx2QZ-S)
![2003 Arctic Cat Carbs 2.jpg 2003 Arctic Cat Carbs 2.jpg](https://www.snowest.com/forum/data/attachments/221/221498-4aa81e99efbfc5599e142806d862e192.jpg?hash=Sqgeme-_xV)
![2009 Polaris Assault Dragon Exhaust Pipe.jpg 2009 Polaris Assault Dragon Exhaust Pipe.jpg](https://www.snowest.com/forum/data/attachments/221/221506-15e81f9264a74a06e2f14030afffc79c.jpg?hash=FegfkmSnSg)
