cat 1400 psi top end
Will they fit 900
I am looking for a big bore kit for my kingcat 900 e.f.i. Just curious if these will fit and why are you selling them. Do I have to buy big bore pipes or will slp twin pipes work with them. Thanks!
What case modifications are required to mount the cylinders?
Do you know what it would cost to true the crank and replace the PTO bearing.
Just trying to get a handle on what it might cost me to put it all together.
Do you have intakes and carbs, pipes etc? I know these are available elsewhere if you don't em.
It depends on the condition of the crank. If it is just the PTO end that is out of true then any decent engine shop should be able to spread the cheek and get it to come out true. If more than one part of the crank is out of true then it probably needs to be disassembled, inspected, put back together and trued, and then welded. I would send it to Crankworks, it will probably run $370. They did my 74mm stroker triple and it made it through about a case of belts before it started to move.
Crank needs a new pto end about $400 thru crank works and the crank needs to be assembled.
