C
Hi All,
First of all, I have been reading your posts for the last two seasons and thank you! I've learned a ton. That said, my 05 RMK w/ a Carl's 975 kit took a dive last Saturday. I took off the top end and while the pistons/cylinders did not seize, a portion of the lower housing on one cylinder chipped off and at least one bearing on the crank is grinding.. I'm told to get her back on the snow, I would have to rebuild the crank, purchase a cylinder, pay to get it bored out and replace the pistons while i'm in there.. None of which I have ever done before.. Anyways my questions to you are:
1. I see a stock 05 900 motor on ebay for $1500.. Could I buy this and install it without too much trouble? Or is there programming of the computer and other things that need to be switched out since it would be going back to running pump gas?
2. Is it worth more than the $800, I was offered by a guy who is willing to part it?
Cheers to you all!
Cheers to you all!
