carbon E-Tec 800 turbo build
E-Tec turbo 800
picture of belt drive,
Titanium A-Arm's
It will have our new oil less turbo. Lightweight no pump and fast spooling
This is the ultimate turbo designed for 2 stroke boost application. Here is a short list stating why this turbo exceeds everything else on the market today.
 Perfectly matched aerospace grade, full compliment twin silicon nitride ball bearing system
 Exclusive loaded, cage-less ceramic bearings, no side or end play
 Precision CNC machined aeronautic grade billet aluminum centre cartridge
 Custom billet compressor wheel designed for 2 stroke application
 Tighter turbine/compressor wheel to housing clearance
 Water cooled jacket
 True oil-less, no oil feed or oil pump required
 Smaller, lighter overall size and weight
 Direct Garrett turbo bolt in replacement
 Lightest rotating mass
 Fastest spool up and best throttle response available on today’s market
 CNC aluminum centre section anodized with color options
powderlites.com
250-836-4422
So this is an XP? Why didn't you went with an XM other then because the donnor sled is an XP?
the xp and XM have the identicall chassis. if you put XM a-arms and all the suspension geometry the same way. its the same sled. mainly plastic differences.
This doesn't answer my question! I know all of your affirmations but why not built a XM instead of a XP since this is a new built :face-icon-small-win
Dave, on the picture of your built, the right foot weel is of an XP so you just can't go on and say you are going to order XM plastics, this doesn't work. Go on with the XP, that's ok but my point was why not go with the new XM trend instead of XPs!
E-Tec Turbo build
Yes you are right I over looked that and even if I order up new foot well parts and redo them it will not be as easy as XP.
Hummm I better keep checking other parts as well. Thanks Gros Chien
