Carb Rebuild Kit (or new Carbs) for 2004 King Cat?
Rob.G
Well after a year of having this thing I pulled it out of the trailer yesterday for a test ride and discovered gas running out the bottom of the sled I just turned it around and put it back in. I'm assuming that one of the floats in one of the carbs is stuck, although it ONLY leaks when it's running. I haven't looked at it since.
So now I'm starting to research what I might have to do with it. Nobody in or near Reno seems to work on Arctic Cats so I guess I'll either rebuild the carbs or replace them. I'd sure like to get the thing running before the end of the season. I'll probably put it up for sale but I want it to be turn-key ready if I do.
Suggestions?
Suggestions?
Di
Suggestions?
I Didn’t press quote , why it quote ?
Anyway, carbs on anything Kinda my specialty.
Come drop it off, with fresh gas and $ to get started.,
Rob could just be a cracked delivery hose from the fuel pump if it only leaks when running by the way how did it run when you had it started ?? If the float were stuck it wouldn't run very good cus it would be pig rich on one cylinder ??
Hmmm good point. I'll check that. Too cold to deal with it today. Is the fuel pump on this thing inside the tank or outside?
Outside usually mounted to the tunnel below the carbs and jackshaft has a pulse line coming from motor and at least one delivery line going to carbs !
Thanks! I was mentioning this to somebody else and they said I should rebuild the fuel pump too. Would you agree? Or is it just a replace instead of rebuild item?
If you can find an OE reasonable replace it have seen mixed results rebuilding some good some a waste of time ..leaked
You may also just have a rotted off water trap on the float bowl. That will just run fuel out while it's running. Especially if it's sat with ethanol gas in it.
By "on" the float bowl, does that mean it's something external that I can replace?
Yes it is a rubber water trap attached below the bowl catches water so it doesn't sit on top of your mains and make sled go boom , forgot about is it those since mine is a fuelie😎
I was going to suggest that very thing. We had a carbed 900 that they were cracked and leaking on.
No reason to really replace the carbs unless you know there is a problem. Usually a good cleaning is all that's needed.
