Carb Mystery....
smv sledhead
Okay- I have a 2001 AC Sno Pro w/ a 720 D&D kit. All winter long the left cylinder would not work. Compression was fine, and would run with gas poured in the plug. We switched every jet, slide, needle, choke, spring, screw, and everything in between, but could never get it to run. I finally ordered a new carb and put my jets in it. Voila. It runs. But what in the world was the problem?? Anybody have any idea, or has it happened to anyone else??
Thank You in advance.
did you ever switch carbs side to side..sounds like the only thing you forgot and should have been the first..??...bet your carb body was cracked...thin line crack..
Is it possible you missed checking an orifice in the carb and it was plugged/restricted?
