N
nathaniel11
i have a 2007 summit 800 and was just wondering what people think about running with the carb heaters on or off?
I believe there is a recommended temp range in the manual for turning it on. It isn't all that cold but there is apparently a lot of moisture in the air at that particular temp range as I recall.
I have never had to use it.
I believe the manual specs. say 40 degrees or below. You can download a free manual at skidoo.com. Just click on sleds and choose operator's guide and you're off to the races. Good Luck!!!![]()
I will be the one to venture away from the group here.
The only time to date that I have used mine on my '02 is when it was -30*. Wouldn't dream of idling and the slow stuff wasn't much better - and at -30* there realy aint much fast stuff eh?
Turned on the heat and in less than a minute all was fine.
Per the "available moisure at low temps" - I think that when we go and stir up the powder and pour some on our intakes and some on our pipes that what makes sence for planes aint exactly applicable to the snowmachine. ???
