snowchaser
2009 Polaris Dragon 800 W/ new top end and 2010 flash
Riding elevation 3500-6000 Ft.
Fuel 50/50 Non oxygenated 92 / Trick 114 (100 Octane)
Pump gas turbo kit with EBC (Rev AAD) and Push to pass
Boost 8lbs / 10 on button
Boondocker Fuel box (5B220802)
EBC settings:
Set HP +10 @ 4000 ft
Alt comp +12
+ HP btn +10
PT/CAL +68 (0 boost on fuel box)
Boondocker fuel box settings: (simple tuner w/ ADA)
3000 LO -01 MID -03 HI -06
5000 LO 00 MID -03 HI -07
Pressure LO 38 MID 48 HI 58
RPM 8450
Max EGT 1254 deg both cylinders
Plugs PTO dark tan MAG slightly darker
OK, now with all that said. The sled runs at 4500 ft like a scolded dog……still a bit fat as I cannot get above 1250 deg (target from Boondocker was 1300 deg). Plugs verified at this fuel and egt setting, about a pinky finger nail of piston wash. These fuel numbers seem very extreme and lean compared to the Boondocker recommended starting numbers of 00 @ (3000, 5000 LO, MID, HI)? I kept removing fuel from the recommended setting until the top end bog stopped and I ended up at the above settings. Now, when returning to the truck and dropping below 3500 ft the sled has the bad on/off bog again at full throttle, but runs great at lo to mid throttle positions? I thought it may be det….but the light on the dash does not flash when this happens…..plugs and pistons show no sign of det. Can you give me some much needed insight?
Also am I correct in thinking the 3000 RPM setting is for no/lo load situations and the 5000 RPM is for mid to hi load? Trying to get my head around this. Please advise.
Dave
EBC settings:
Alt comp +12
+ HP btn +10
RPM 8450
Dave
