im pretty sure my stator is bad on my 11 pro. can you send it in somewhere and have it rebuilt? if not, do they have aftermarket ones? thanks
thanks guys. well first i only had 7.5 volts coming out of the regulator, then i did the ohm test on the stator and for both the yellow to yellow i read 0 ohms, orange to orange i got .4 ohms, green to white/green i got 193ohms, and white to white/red i got 192, and for the ground i got .9. i did replace the regulator and got no change, so i figure the stator is the problem right?
Ya on the two yellow to yellow I read 0 ohms, not open. I measure it with a Klein meter from so its a decent meter. For the ground I measured the black one from the stator to where all the grounds come together where the bumper bolts up. I tested between each one and ground and it read open, except for the black one which read the .9 and that one is the engine ground
