Can you rebuild a fox float pump?
As far as I know there are no repair parts avalible for those pumps. I did a lot of looking when mine went bad and ended up buying a new pump. They are a big rip off when you can buy an electric 12 volt pump for less!
You might be able to buy a mtn bike pump for less. It's the same pump I use for my fox fork and shock on the full squish bike.
Although you get what you pay for. Not sure how accurate a cheaper version might be.
Fox pumps are JUNK! Do some research on pumps for bike forks, then buy one off ebay. works MUCH faster and dont leak air. Eric
thanks guys. I got a small pump almost the same as the fox pump, but without the gauge.
My tire pressure gauge only goes to 50 lbs so I can't use that.
People have been telling me to use a compressor but I'm nervous over that.
I'll look at the mtn bike pumps.
Whatever you do don't use an air compressor. Find a cheap bike pump before you do that.
Use your little pump without a guage and pick up a zero loss gauge. They are usually a small dial gauge. The pressure in the shocks change with very little air loss.
