M mod03rmk800 Well-known member Feb 14, 2010 #2 25ft pounds loctite 242 start in the middle and work out alternating top and bottom switching back and forth between cylinders. Put a little silicone(black) under the bolt heads.
R Ron ACCOUNT CLOSED Feb 14, 2010 #3 And torque in increments so that it takes 3 passes. Torque to 10lbs, then 18 lbs, then 25 lbs.
D dub Well-known member Feb 14, 2010 #4 Thanks guy's!! Top end looks perfect after 700 miles on update. Going to try the new Poo map with SLP PC update overlay and new pipe sensor...
