Can I fit a 4 inch riser on an 08 M1000 without extending cables?
H
HiWaYman92
Just as the titles says, I have an 08 M1000 with a 3'' riser, and it's just not quite enough... Can I fit a 4'' or larger without extending everything? And, if I can't, what all needs to be extended? Just throttle and brake, or all the wires too?
riser
hey i have a 2" riser on my 08 m8 and i was wondering if i could put a 3 inch on without extending anything it seems tight as it is with all the cables but it seems you maneged to slap a 3 inch on there without extending any of the cables and wires?
My snowmobile salesman has a 4 inch riser on his 08 M8, i dont think he had to extend the cables but i am not posotive about that.
My buddy put a 4" on his 08 m8 and didn't have to extend any cables at all.
Hope this helps.
Trent
ok, sounds like I may be able to go 4.. are there any tricks? Do I have to re-route anything? A detailed layout would be great for an idiot like me!
I have about a 5" rise on mine. I extended the brake line and rerouted the throttle cable. Had no problems, works great. I had a hard time trying to find a throttle cable extension for the m since it has a ball instead of a hammer at the end of the cable.
So... I want to go atleast 4''. What brand of riser do you recommend? I bet 5 inches would be even better... anyone have a setup for sale?
Okay, so today I ordered an adjustable 4-5.5'' rox riser, a brake cable extension, and an 09 Sno Pro throttle cable. Can I make this thing work with these parts? Is there enough wire for the bar warmers and switches? I hope I can make this work, sounds like I can, but I want to hear someone say that they have done the exact same thing to the exact same sled... anyone?
