can a 153" go under a crossfire????
just wondering if the skid frame and all off a M7 153" 2 1/4 would fit under a crossfire, and if so would i have to change the gearing, if i do would the M7 gears and everything slide right in the crossfire, crossfire is a 600 and both are 2006, thanks
it fits.. the skid frame and DD/gearing etc..
you'll only need a set of drivewheels or an axle from a M cause the M has a 3" pitch and the CF have 2.86" or something..
do not forget the tunnel extension you go past 144 with crossfire you start hitting backend
you can, you need tunnel extensions, i would do the gearing, i have a 136x2 on my 06 CF7, went to a 57-63 instead of a 60-60. woke it right up in the deep stuff.
