Camso track in Yeti rubbing
GKR
Just installed a Camso DTS track in a 2016 Yeti and it rubs up near the front of the tunnel by the drivers on the very outside tips of the outer paddles. Is this typical and is the obvious fix to trim the tips a bit or just run? I think it will make a hell of a racket if you just run as is.
Yep, same deal when I put the yeti camso 12.5 wide 2.5 paddle track on my 16.5 yeti. I trimmed the out side edge of paddles a bit and does not hit. Only about 1/4" width clearance on each side at front as well. 80-90 hours on track last year worked great, no issues. Maybe a little noisier as the track windows are clipped on every other window.
  • Like
Reactions: GKR
