camso dts 129 on ktm 500exc
B
bcab
New member
hello am a newb to snowbikes just put on a 2018 camso kit on my 2015 ktm 500exc-does anyone have any experiance with this setup mainly looking for input on the strut rod adjustment as there instructions are pretty generic-set up with bushing #2 setting on rod and about 15mm of threads showing on rod end and forks flush with top of clamp the rear of the track is about 1/4" off the floor-oh and i left the limiter cable in factory setting. just looking for best trail stability and handling-but im sure at lot of it is snow conditions ext-also am probably around 230lbs or more fully geared up-Thanks for any input:face-icon-small-hap
My setup is pretty much identical, except my bike is a 2014. But you're on the right track (no pun intended). I have my forks set flush and strut length set so the track sits flat. I let out my limiters for the last ride and I think it did well in the deep snow, except that it wanted to lift the front more than it needed to. It was fun but a little harder to control. I don't think it helped to make it easier to ride down a road with frozen ruts -- it's still a handful on the trail. The next thing I might try is what you said -- shorten the strut a bit so that the back of the track is about a quarter inch off the garage floor. We'll see. But I love the bike and kit and how well I can get around in the trees and deep stuff.
I have order a 2015 500 exc fit kit from camso and it came with 22mm bushing for the front axle ( ski )
ktm part list say the front axle is 26 dia
Just curious did you guys get 22 mm or 26 mm
Asking this becuz I want to install this on a 690 and according to ktm parts list. Both bike are shown to have same 26 mm axle
I don't know for sure what size my axle is, but everything that came with the kit for my 2014 fit great.
front axle bushing
my 2018 kit came with the correct bushing for the 2015 ktm 500
limiter cables
what are you guys running for the limiter cables-in or let out or does it make much difference? Thanks
limiter cables
Out for powder, in for trail. Factory directions are backwards. I leave it out all the time. If you want better trail manners slide forks up 1/4-3/8” and turn down rebound on front forks and compression turn up.
