Camoplast Extreme 2.5 pictures
Anyone have any pictures of the Camoplast Extreme 2.5 in 16 wide?
Understand that the outside paddles are cut in some and would like to see what the track looks like.
Thanks
Extreme 2.5
The paddles on the 2.86" pitch 2.5 extreme are only 15" wide. The belting is 16". The paddles on the 3" pitch track are a full 16" wide.
Thanks, have 2.86 drivers and really don't want to run the 3 pitch w/those drivers.
Would still like to see pictures if anyone has some.
2.5 x 16 CE 3.0 pitch
Here you go.....this is the 3.0 pitch.
Edit - I need to add that I center ported, removed every other clip, and removed the center rows of nubs.
No problem, the 2.86 pitch looks the same except the paddles are inset .5" on each side of the belt as mentioned above by Robbie.
is it a noticeable diffrence with the .5 offset? even with that said why wouldnt you just run a 15 wide belt, less weight really and better snow evacuation no?
heres a pic and i didnt notice any hinderance to it if anything i thought it was better, didnt get as much vibration when the tunnel fills up with ice and snow.
that is not the new style extreme. it has no notches on the ends of the paddles and the sides are turned in.
that is the latest 2.86 16wide 2.5 camo extreme, look at the outer paddles carefully and you can see that the lug doesnt start till .5" in on the track
