At BLACK DIAMOND XTREME we have belt drive kits in stock for the 2012-14 models, 2015, and 2016-17 models.
Many different ratios available.
SyncroDrive for the 2015 Arctic Cat 800 Proclimb / ProCross.
You will have the following benefits from this system.
1250 Grams (2.75 lb) less rotating mass
12 lb weight savings (18 lb with oil delete)
Currently available in Gear Ratios from 1.50 to 2.63
No break in period
Gear and belt changes in minutes
Inexpensive 8mm pitch belts
2015-2017 MODELS COME WITH NEW HEAVY DUTY JACKSHAFT WITH MORE SPLINE SUPPORT AND BOLTS THE UPPER PULLEY ON FOR STRENGTH INSTEAD OF USING A C CLIP. NO DRILLING OR TAPPING OF THE STOCK SHAFT REQUIRED.
2016-17 MODELS COME WITH BDX JACKSHAFT WHICH IS A ADDITIONAL 2 LBS LIGHTER THAN THE STOCK ONE!!
NEW LIGHTWEIGHT UPPER PULLEY WITH STRONGER WIDER SPLINES!!
The standard kit come with an oil injection block off. Also available with a lightweight oil tank
2.63 ratio is a common ratio for a stock or engine mods or 3" tracks M800/M8000
2.42 is common ratio for a big bore
2.33 is common ratio for a turbo
Here is a link to them on our website
http://www.bd-xtreme.com/index.php?id_category=51&controller=category
No break in period
