I think your tech is correct.
http://www.cycleterminal.com/250-connectors.html#SC250
I think these match the factory connectors if you want to replace them.
It would be nice to find tinned terminals for these yazaki stator connectors.
Here you go.
https://www.corsa-technic.com/category.php?category_id=153
If you scroll down to the bottom of the linked page. All the connectors are available in tin plated as a alternate connector. Now we just have to chase down the relays in tin plated as well.
The photo shows brass... with alternate part numbers in raw brass and tin plated...
Are you sure those terminals are tin plate??
I personally would NOT use di-electric grease on the pins (as it is NOT conductive). The only place it should be used is the rubber bellows seal. IMO.
I changed my motor mounts and no improvement. The motor just does not sound happy anymore and idle is down. Looking deeper I have found 2 things. Idle voltage from the TPS was now at .99 volts were it used to be at .94 secondly here is what I found in the cloth bag above the motor. Still need to go for another ride to see if it is fixed.
