Burandt suspension upgrade shims?
I'm reshimming my rear float shock (taken from M -08). Checked today shimming differences between stock M8 SP shocks from -08 to -10. Seems there's not much differences between -09 and -10 but -08 is totally different (crap).
So does anyone know what differences there's between Burandt Backcountry upgrade kit rear shock and stock -10 rear shock? I don't like to buy whole kit as I'm going to put WP 46mm front shock (designed for SnoPro racer). That shock will rock! :)
What you will get:
Complete rebuilds on both the front Zero-Pro shock and the rear Fox Float shock.
Max Air Volume Bearing cap installed in the Float.
Hi-Flow EVOL style damping pistons in both shocks.
Improved shock valving in both shocks.
Mine are being done right now, hopefully they include the spec. sheet.
Ended up setting valving to stock M8 -10 except changed damping piston to one which has about 0.09" orifice (didn't measure it). We'll see how it works.
Here's a installation pic with new front SHOCK - not any silly stick :) Qreiff may recognize the rails ;)
main.php
