Burandt Backcountry Upgrade Kit $292.50 installed
C
CarverPerformance
New member
Let us install the Fox Racing Shox/Chris Burandt Backcountry Upgrade Kit into your existing Arctic Cat M Series Fox Float rear suspension.
Send us your shocks and we will service your shocks and install the kit for $292.50.
What you will get:
Complete rebuilds on both the front Zero-Pro shock and the rear Fox Float shock.
Max Air Volume Bearing cap installed in the Float.
Hi-Flow EVOL style damping pistons in both shocks.
Improved shock valving in both shocks.
The Result:
A plush feel on the trail and improved weight transfer to help get your sled on top of the snow.
If you have any questions, please feel free to give us a call at 218-964-5670 or email jodie@carverperformance.com.
Do you offer anything similar if we have Floats in the front and rear. Fox Zero Pro in the middle.
Upgrades to Float 2 or equiv or any other better options??
Thanks.
this is just the rear suspension set up guys. zero pro front arm shock (rear skid) float rear shock (rear of skid). it does not have anything for the front shocks, you would ask to have them done seperately. ski
FYI: Any Fox Shox dealer can do this, mine just bought the components for the kit and has them in stock. If you are really interested go to your favorite place that rebuilds your shocks and ask for the Burandt setup from Fox.
I know I am still in mourning from Burandt going to Poo :(
i would like to see this tested against the holz set up. or in combination with some from each kit. front zero X sounds like it needs a heavier spring or multi rate spring to help the trenching and trail issues.
ski
We can perform any of the upgrades, Float to Float 2, custom valving, Burandt rear suspension, etc. Just let us know what you are liking and disliking about your machine and we can set it up more for your liking.
ttt for carver, for a question. does this upgrade have a different rear skid, front shock spring? curious on the differences between this and the holz M series upgrade. appears several reports state the M's need a stiffer spring up there to relax the ski pressure.
i understand the "B" kit is for better trail manors and weight transfer offtrail. does it allieviate some of the front and "heaviness" from the stock set up. mine is an 09 m8 153sno pro. thanks for your time. ski
