bumping up the fual pressure on turbo pro
P
purepolaris600
hay guys just had the idea of bunping up the fual pressure on silber pro hoping to clean up the bottom end. what aré your guys thought or expereance thanks
usually a bog is to much fuel or poorly atomized fuel, backfiring and popping is to lean a mix.
What year of kit do you have
kit
i have a silber 12 kit with the dobock box it flat out rips when you get it above 5800 but kind of spitts and sputters below that.that i cant seam to tune out. it is geared 19 43 running 11lbson 100ll with water to air innercooler and power addiction head
If it is a gen 3.5 with a external map sensor i would see if you could reflash you fuel controller And have one of the blue zones set up for lower map voltage adjustment. This enables you to set when your secondarily injectors roll in. This gets rid of the midrange lean spot as well.
i have one of those 3.5 boxes with the new attitude few map in it works great. i have a spare for sale if you want to try it. $200. pm me about it.
