Built YJ Wrangler.
titaniumbadger
For Sale: 1993 Jeep Wrangler built for reliable back country exploring. 5" Procomp coil spring conversion lift. ARB Air Lockers front/rear. Curry Enterprises built Dana 44 rear end. 4.11 Gears. Front end has been upgraded with Warn Chromoly axle shafts, larger u-joints and Warn manual hubs (CAD eliminated). Transfer case has the SLE modification and was rebuilt 15K miles ago. Custom dual u-jointed heavy duty driveshaft. Warn HS9500i winch, used 3 times with roller fairlead. Hard top, Safari top. Hard Doors and soft half doors. Trail cover, windjammer. Swinging spairtire carrier that hold 2 jerry cans. High lift jack mounted in rear bumper. Dual optima batteries with a wrangler power products isolator/controller and 0 gauge battery cables. Borla Stainless steel header, Flowmaster muffler. MSD ignition. K&N filter. Sun Performance rocker skids. Full welded roll cage. Off road lights. Safari rack for the hard top. Tow bar. Newer seats. Pioneer six disc CD changer. Tuffy locking center console and rear toolbox. Locks on the hood and hard door hinges. Stainless radiator guard. All weather CB radio. AX-15 transmission, rebuilt about 15K miles ago with B&M short shift kit. Grant steering wheel. Double tube rear bumper with receiver hitch. 33" tires on 15x8" aluminum wheels. Bushwacker extended 6" fender flairs. Custom paint job. This Jeep really turns heads. Most of the parts have been installed less than 10K miles. Stored indoors (mostly). Odometer has about 130K miles on it, but many of the miles are towed miles. Many upgraded and newer parts. This jeep drives great on the road and off. Well over $25K invested Selling for $9,000 OBO. Located in SE Idaho. Contact me for more pictures and information. (208) 360-4341. Titaniumbadger@msn.com.
18574_7jE5o
Thanks
Thanks for the comments. If anyone out there is thinking about just buying a decent running Jeep and building it up, let me go over the costs with you. You will be WAY ahead buying one that is already built. Even if you don't want to buy this one, drop me an email, I never mind talking about Jeeps. :)
What is the AX 15 transmission you speak of? Would you meet at the Canadian border?
ax-15
Hello,
The AX-15 is a 5 speed manual transmission with a 3.93:1 first gear and an overdrive 5th gear built by Aisin. It is also the strongest stock transmission for YJs. If you buy a YJ jeep, try and avoid the Peugeot BA-10 or the AX-5.
As far as meeting you at the boarder, I'd have to think about it, it's a long way from here. Where do you live? You would have to be pretty serious, I wouldn't want to go all that way just to have someone look at it. Let me know if there is anything else you want to know about it.
Thanks for the questions though.
Shawn
What are you running for a fuel system? Is it still the stock Carb?
Engine
I guess I failed to mention the engine in my original post, kind of a big oversight. It is a 4.0 liter inline 6 with multiport fuel injection. It has an MSD ignition, 8 mm Taylor silicon plug wires, airraid throttle spacer, Borla Stainless Steel header, K&N filter, high flow cat, flowmaster muffler. Engine internals are stock, it runs and sounds great. You should easily get 200K miles out of this engine, it has about 130K on the odometer, but alot of those miles were towed miles, I'm guessing the engine has about 90K miles on it. The transmission, transfer case, drive shaft and rear end have less than 20K miles on them and the front axles were rebuilt with stronger shafts, u-joints and manual hubs less than 5K miles ago.
Custom paint job.
You can say that again! ewwwwwwww!!
Congrats TechA, I think you got a sweet ride, now lets get them DIRTY!!!
btw, you DO know what JEEP stands for right???
JUST
EMPTY
EVERY
POCKET
:D
p.s. ...... at least I got company now while going to the poor farm keeping the FERD runing :D:D;)
RESALE
For sale again, contact me at btkeele@yahoo.com....
a few new additions.. new tires, shocks, steering linkage, lights, new oil pan gasket... runs great, just don't use that much...hate to see it waste away. Need the space in my shop too...
